Working …
That looks great. Just wondering about the bar at the bottom of the field, where you set speed and direction in sim. Could the be connected to the sim tick in the top menu, so when you toggle out of simulation mode, the bar at the bottom goes away also ? Or is there another use for it outside OS simulation ? Would just make the field screen cleaner if it was not there after switching to GPS source.
Only used in simulation, disappears for real use
I like it!! why not “lean” the section bar on the lower edge of the map? with perhaps the possibility of hiding it, since it is also displayed on the implement itself
To do that you have to modify the code, now I am trying to find out what the superimposed images are on the work table (speedometer, …) in order to modify them
For @BrianTee_Admin or anyone who knows the code, is this to improve graphics on OpenTK?
https://www.codeproject.com/Articles/1057539/Abstract-of-the-text-rendering-with-OpenGL-OpenTK
Nice graphics but sure is a lot of code.
New improvements, I keep up the work
New improvements with neutral style
https://github.com/Vilicat-cat/AoG-New-Icon
Version 1.0
New icons, little tweaks on interface, grouping icons by color.
Enjoy
Very nice graphic !
Math
Thank you, I just try to contribute what I do in this community
