This might be a dumb question but i can see how you get from TNC to SMA but what board gets it to USB or UDP [ethernet cable] and will any helical antenna work like this ie a Raven MBA6.
A mate gave it to me,I am not over impressed with my ardusimple F9P it drops sats a lot the little 20 dollar chinese usb antennas seem to work as good and dont drop out at all but they cant do RTK and i wanted to try something better before buying anything else
Then something is wrong with f9p or most likely the antenna. What is the exact name of the antenna?
Or maybe f9p is set to use satellite system that does not have many visible satellites in your area.
Its an ardusimple RTK2GO lite package,it looses signal around trees and things where the $20 ebay usb antenna,s have no probs.Seems worse when RTK enabled but acuracy free to air is no better than the ebay ones.
Which is logical. When on RTK f9p can only use satellites that the base is also seeing at that moment.
What is your f9p settings?
Did you use a rover setup file for the f9p?
Could you give more details about your Chinese £20 receiver? I’d like to see if it is GPS only or if it supports other constellations.
I’m not aware of any RTK2GO from from Ardusimple (may have missed it), are you actually referring to SimpleRTK2B lite? Are you using RTK2GO for a correction signal? How far from your location?
In any case, higher accuracy in any case results to lower availability (more or less). But the SimpleRTK2B receiver should never provide lower availability when working in the same mode as any cheap receiver. The cheap receiver may not support sbas but if it did, it would give lower availability in SBAS mode than in autonomous but better accuracy with sbas compared to autonomous mode.
Your first message claimed F9P being worse, the second says it is no better, has something changed?
I think its the ANN-MB-00 Antenna for GNSS dual band and yep sorry it is RTK2B lite .The other ebay antenna,s are just those G Mouse ones which are a Ublox 7 and you can reset them to 10 hz in u centre, cors correction is a bit over 20 kms next closest is about 35 kms and in answer to the settings i didnt set as rover didnt think you had to.
I am in Ontario and had a TOP-106 set up for my base station but it seems to have flaked out after 1 year. Do you try to keep yours out of the elements or anything? Do yours last longer than a year?
Thanks!
