Anyone using dual GPS with xbee radio?
Hi all, curious if anyone is using dual GPS with an xbee radio for RTK corrections. I am attempting to setup such a system, but it seems like my f9p’s are not connected. I flashed my teensy with dual antenna firmware, as well as both of my f9p’s via config o magic. I heard somewhere that the f9p’s have to communicate with each other via a uart connection, and that this may be busy handling the xbee. Can anyone confirm this, and is it possible to run dual GPS with an xbee plugged in??
They aren’t showing up ‘green’ in AgIO? I had some quirks with the Config-O-Matic tool (whether it was firmware it was grabbing or the flash process) that was solved with manually downloading the .hex and flashing with Teeny flasher.
I had a green steer board in agio, but nothing else. I put the teensy firmware into configomatic manually, since it apparently doesn’t come with it.
