AOG con antenna trimble
Buongiorno ragazzi. sono nuovo del forum. Ho un sistema di sterzo idraulico trimble, e vorrei aggiornarlo con AOG. E’ possibile riutilizzare la mia vecchia antenna Trimble 372 per il nuovo sistema AOG idraulico? Grazie in anticipo per la risposta.
Your Trimble antenna is not only an antenna, it is also a receiver.
You can set up the B port of the 372 to output NMEA, which is something that could be used with AgOpenGPS.
I am not sure how to set up the B port of the 372 without a Trimble/CNH monitor attached. I am not sure if this setup would need to be repeated by each power cycle.
Does your Trimble 372 have an RTK unlock? AgOpenGPS cannot unlock your Trimble 372 to RTK for you.
Hi, thanks for the reply. The antenna is unlocked for RTK and there are no problems with its management. My concern is whether it integrates with AOG since it’s not installed on the PCB. From the diagram I see at the beginning of this forum, the antenna has its own management, and perhaps by connecting it directly to the monitor with a serial/USB cable and using the LAN for the AOG PCB, I should be fine, or at least I think so. Anyone have any ideas?
