I had this all working and then I bricked my tablet. (Don’t ask - Ok I’ll tell. I had a sun hood being held onto the tablet holder with Magnets - real good ones.) So my new tablet has come and I’m back to setting things up.
Every time The GGA is sent the computer will hang (for up to a 1.5 mins. I think I had it set as before but must not have.
Here is pic of when it hangs.
Here is my list of Mount points. I know I was using one of the bottom 2 because I set up my f9 to recieve all 3 sat systems,
Here is the mesage that frees it from hanging.
Let me know what other info you might need. Thanks
Well… it’s still windows and I can do some strange things. Win 10 pro or win 10 home makes a huge difference.
Try turn off firewall and see if it works… if it does, you can add AoG as an exception in the firewall.
I don’t know if this is Pro or what, But it’s working like a charm with defender off. You are a wizard!!! Thanks a bunch. Now I’ll read up on rules and set AOG as exception.
I got a rule set and then went to try it. It is hanging again. I’ll try undoing the rule and turning defender off and see where I get. I’ll report back.
I wonder if this was the same issue I was getting, I had huge issues with the NTRIP client in AOG causing AOG to hang randomly when connection was lost / re-establishing, causing all kinds of chaos, I just ended up using strtsvr instead, but might investigate when I have five minutes!
I have it tracked down to that it is when it sends GGA - maybe not, I’ll try setting to 0 (turn off).and setting to a lot larger number. I’ll look into strtsv also.
Thats what I meant, sorry typed in hurry on my phone! I just use that, with a virtual serial port (as send my corrections via UDP to dual antenna over ethernet) but works a treat so never bothered to investigate further.
Well, it not that crazy that it will hang during gga because it’s trying to send out your gga sentence in a package thru an tcp port. If your firewall blocks that outgoing port, it will hang… without sending gga it’s only receiving data on a tcp port, what maybe could be open for incoming data…
Here is what I have tried.
1 set frequency to 0. I can not see that GGA is ever sent and it doen’t hang.
2 set frequency to 120. I tries to send GGA and it hangs.
3 set incoming and out going exception for all ports. Hangs on sending GGA.
1 2 were both done with firewall turned off.
3 done with firewall turned on.
the port required for my correction provider is 10000. Is this the port I would make an exception for?
You turned off defender and it worked you said a few messages back… does it work with defender off? Or not at all? Can you try set gga interval to 12? That’s the standard value. (With defender off?
Defender off I can Get 2 maybe 3 GGA sends then Hangs. I’ll have to wait until tomorrow to try - my son took the tractor.
I may have found the problem. My tablet is a 2 in 1 with a Micro USB 2.0. So I have to use an OTG adapter. I’m wondering if it isn’t restricting things. I’m searching to find any other problems with solution. I may end up getting a OTC cord rather than the adapter. I’ll report back.
In the tablet mode I have a USB 3 and It’s working fine on that port.
I decided not to fight the micro USB tablet and run with the tablet in notebook form (USB 3) avalable. Actually pretty easy to modify the tablet holder into a notebook holder. Thanks for all of your help!!
