I down loaded and tried version 6.4.4 and version 6.6.1 of AgopenGps. The “app map” button for making variable rate application maps is not in the menu. I made a couple application maps with v6.3.3. Was there issues with the app map button that it was not included in the newer software versions? Is there another way of making an application map for the newer AgopenGps versions that is being implemented?
It was just a try out and half baked solution. We need to use shape files and layered data for section mapping. It was pretty simple though…
Thank you for the explanation. Is there a place I can find the best procedure for making a rate map? Is there a procedure for making a rate map currently?
