Hello
Does anyone know if Arduino ASX0006 can do the job instread of
“Mini ENC28J60 Webserver module Ethernet Shield board for Arduino Nano v3.0 top”
Hello
It could probably do the job, but the pins don’t match with the Nano. This shield has a so-called MKR form factor.
Okay, can you explain what this board does or why its needed?
Which board, the enc28j60? You need it if you want to use an ethernet connection instead of USB to the Arduino nano.
Hello
Okay so actually I can skip to put it on? I can just use usb
