ArduSimple simpleRTK2, pro or budget
Hello
I’m on my treasure hunt around the world to make my Kaupoi v4.1 with Panda NTRIP
Just about to order ArduSimple simpleRTK2 pro
or should i just go with the budget model?
Am i only going to gain a couple led’s with PRO
and would be no better off
PRO
The new Pro version is the latest generation supercharged with new features:
– High power XBee Socket to connect high power devices, like 4G NTRIP Client and XLR at 1W output power.
– Selectable UART1 / UART2 connection to the XBee socket, to be able to send UBX protocol over the air.
– Compatible with Sparkfun qwiic interface and I2C interface.
– Dual USB-C connector
– “NO RTK” LED in red color
– “GPS FIX” LED in green color
– EXTINT and TIMEPULSE available on the JST connector
Budget
Cheers Gordy
Your correct, there is zero advantage using the new pro version (for the tractor end anyway) most users just using the basic with basic antenna.
https://www.ardusimple.com/product/simplertk2b-basic-starter-kit-ip65/
thanks CommonRail :+1:
The only point what I thinking about is to trying connect the teensy + F9P + BNO085 together by new provided Sparkfun qwiic interface ( I2C interface).
Hi
I have bought a basic starter kit as per the link, I went through the setup in Ucentre which I think worked ok, though it won’t let me run the programe again.
I’m only going for a simple lightbar guidance as a stand alone unit which is running through a USB cable but having trouble connecting it all together.
On the board I have steady red & blue led’s, & a flashing green beside the antenna, & I have got the antenna connected just now, but don’t know the next step? any help much appreciated.
