Let me start by saying this is my first post as I am at the very early stages of learning about setting up AgOpenGPS and RTK GPS so if my questions don’t make sense please let me know as this is the only way I will learn…
My Goal
I am looking to get sub 10cm accuracy GPS in my tractor to allow me to more accurately with a drill seeder, boom spray and spread fertilizer with a spreader.
Terrain Details for Context:
The Farm is located in NSW, Australia not big (only 100 Acres) so the furthest distance between the Base Station and Tractor/Rover would be ~700m but hilly with trees.
I have used the line of site elevation tool (Solwise - Surface Elevation Tool) below to give you an idea of the terrain to get an opinion if you think it would work using static base station located at the Shed located at the Blue Pin on the screenshot vs the rover located at the two locations shown below by the 2 Red Pins and their respective Line of Site Elevation Profiles. (see below)
Below are 2 furthest points the Rover/Tractor (Red Pin) could be from Base Station (Blue Pin)
Option 1: simpleRTK2B board and NTRIP via mobile internet
I bought a Ardusimple simpleRTK2B Starter Kit and started testing it using NTRIP GPS correction data from a public Geoscience Australia AUSCORS NTRIP Broadcaster which provides free and open access to real-time GNSS data stream from a base station located ~20km away from me. I used my 5G Mobile internet to connect to the broadcaster and worked well but when I tested it around the farm I found, as I suspected that my mobile network is unreliable in my area so only worked for about 70% of my property so was too unreliable.
Option 2: Setup Static Base Station to generate RTK corrections with LoRa Radio Connection
I bought a second Ardusimple simpleRTK2B board and GPS antenna as given my unreliable mobile internet I have realised I need my own Base Station with a radio to transmit the RTK corrections.
My research lead me to look at the SparkFun LoRaSerial Kit - 915MHz (Enclosed) and the Ardusimple Radio module Long Range (LR) to transmit RTK Correction Data between a static Base Station and a Rover in my Tractor… but from what I have read given my terrain it was suggested that LoRa radios would also be unreliable.
Option 3: Setup Static Base Station to generate RTK corrections with RFD-900x Radios
RFD-900x radios seem to be used widely for transmitting telemetry data and commands between drones and controller base stations and was suggested I use them.
Details of the RFD-900x I was looking at but there is tons of video’s setup guides for their use in drones but am struggling to find any online guides or examples of people using them with base stations and rovers for basic GPS and wondering if there is a reason for this…
Questions :
Basically does any have experience using the Ardusimple simpleRTK2B board with RFD-900x Radios for a RTK GPS setup??
Given the distance is quite short (less than 1km) does anyone have a view on if the RFD-900x Radios would work for my terrain given it is not perfect line of sight?
Thanks in advance… I am documenting my journey in the hope once I can get the my GPS accurate that my mistakes / stumbles can help others as I move onto working on using AgOpenGPS.
FarmingEvangelist
