ASD interface
Hi,
I was hoping to do section control on a Muller Spraylight which has an rs232 ASD interface. I found an existing interface from CoffeeTrac ;
https://www.youtube.com/watch?v=obbyNXBeFzo
https://github.com/Coffeetrac/AG_ASD_Host/tree/1a26b95a3864874f46e3783dbb8b90f770ae64ef
Does any one know if this will still work with the latest versions of AOG, or have any other suggestions.
Peter
Rauch controller was made by Mueller elektronik in germany.
So i think it is the same comunication protocol. it is RS232.
I think you need only three wires TX, RX, GND
But you need to connect in this way
TX of mueller = > RX of MAX3232
RX of mueller => TX of MAX3232
GND of mueller => GND on MAX3232
RS-232-male-to-female-connector-pinout
Thankyou for the pinout diagram that is very helpful. Have you done this yourself? Does the Coffeetrac esp32 program still talk to the AOG, it looks to me as though the sentences for section control sent to the ESP32 may have changed ?
Peter
I find the schematic on google.
The ESP32 is connected to pc by usb connection.
In the version 5, the comunication is managed by AGIO.
I do not know how AGIO works and if there are some difference with old software version.
For the cable, you can buy a DB9 rs232 serial null modem cable
Do you have cable connection diagram for amados plus?
https://et2.amazone.de/zeige_teil.asp?navid=2365
There is an ASD adapter cable harness. (Code NL394)
NL394
yes this cabel you have its internal connections
hello did you have use the Coffeetrac system please ?
Hi,
I am also interested to implement this interface to use it with an Axis 40.2M-EMC (W) with Quantron A terminal. Does some made some progress on it in the meantime ?
There are several questions / unclear points:
  • Does it works with AOG v5, and does someone use it?
  • From what is see in the specification and the video, it seems that was developed to work with two sections only (right/left), does it also work with a 8 sections AXIS ? It seems that not…
  • Does someone have a documentation or some more info about the specification of this ASD protocol , in order to eventually adapt this interface to make it working with a 8 sections machine.
  • Regarding the cable, it think that’s nothing particular itself, simply need to link from Quantron A as Stabilo wrote:
    o TX (Pin 8 of Quantron) = > RX of MAX3232
    o RX (Pin 7 of Quantron) => TX of MAX3232
    o GND (Pin 3 of Quantron) => GND on MAX3232
Thanks,
Regards,
This code works with v4, but I’m modifying it to be compatible with V5. I haven’t tested it yet but it’s for use with a quantron so I don’t know if it will work with your box. either if I had more information on the ASD protocol, I think it would not be complicated for it to manage more sections, a good part of the code is already done!
Amazone saying here that the ASD protokoll is open for all, so should be able to get the documention for ASD
I think what they mean by open to everyone is that any manufacturer can get it, but with the purchase of a license :sweat_smile:
I might ask my amazone dealer for a technical contact I can talk to. Now I have a company I can claim to be an OEM :joy:
Sent a second mail to the dealer here in norway now. Hope to get an answer
In the meantime I also analyzed the code , I see that data sent/expected by AOG between v4 and v5 are not the same , as you said the code has to be adapted anyway for v5.
I use the Quantron A also. For the sections, I am still not sure if the current code can manage several section or not. Unfortunately the code is poorly commented about the data send/received with the ASD protocol. Without a documentation it will be difficult.
Regards,
hello did you try to ask about ASD protocol please ?
Sorry, I didn’t have any luck getting the spec.
Hello, is it possible for you to provide me with the code
Hello, is enybody modify code to work with v5?
Hello
Has there been any progress since then?
