Hopefully somebody can help me / has come across the same problem.
Sowing Oilseed Rape and stopped for a break, then on restart auto steer button won’t stay in ( ie green). Lights green for a second and then kicks out.
All seems ok in Agopen and have RTK fix.
I have disconnected the motor in case of a problem there but no different.
All powered as should be.
I’m guessing at a problem with the motor driver ( md35) or an arduino issue but unfortunately I don’t have a spare to try. I have reloaded the sketch but no different.
Using 3.09 in case that makes a difference.
I mean the optocoupler input labelled STEER, it’s your autosteer on/off switch/button. What version of AoG are you using? Do you have red or green light in the bottom right of the mapping area?
Just an update to my problem. I think it was a bad connection with the wire to pin D6 on the Arduino. A good reason to get onto PCB as soon as possible !
Thank you to those who tried to help😊
I am running v4.1, and anytime I change an offset, it does the same thing. I can go to module configuration, which I don’t remember v3.09 having, and resend to module, and autosteer button starts working again.
