how to set min. speed motor in new ago 5.7.2?
Set min to the lowest value that actually makes the wheels steer while moving.
yes i know it but how to find precise value in this new version. you made a jpg tutorial how to find it in 5.6 low and min were changed to 1 then low was raised until it started spinning in this version there is no “low” there is p, max, min (ago 5.7.2)
First you can try the wizard, there is a step to set the min value.
To manually set the min value.
1-Put in Drive mode(the green tractor)
2- put the P value to 1, min to 1, max to 255
3- drive at 1 to 3 km/h
4-move the arrow to give some error
5- increase the Min value until the wheels move slowly.
At min pwm the wheels must move.
after that you set P and max to move the wheel as fast as possible without overshouting using the ±5 deg button
Low was removed because it’s not needed if min, P and max are set correctly
I try to use the wizard tht is very convignant
But for min value chapter It will be impossible to have an action and finnaly i put to the maximun without result
at the end of procedure when you test it willbe clear the Min value is not correct
So i use the manual mode to set this min value and it works
@BrianTee_Admin Can you check in the sofware the wizard really work for min value setting
Did you drive at that moment? no speed no PWM
i think but i need to reconform again
