I installed a 60L valve on my Case Ih 9270 this spring, it works great in autosteer mode (although a little slow for 10mph speed) but in manual mode you have to steer very slowly or steering locks up.
I’ve tried removing the load sense line and putting back to stock, and adjusting the relief valve but it didn’t do anything.
I think maybe the 60L valve is too small, the tractor steering hoses are much bigger and I had to adapt them down quite a bit to work with the valve -10 down to -6
Why not just Tee into the steering lines, cannot imagine it has a reactive orbital.
Then no oil flows through the Baraki valve in manual steering.
Steering locks up and it does not steer until you restart engine? We had that with case mx 135, hydraulic pumps plate was worn out.
Just the guy I was looking for, apparently you have a youtube video showing this?
No if I let go of the steering and go again slowly its fine
do you need a shuttle valve between the T for the orbital and baraki valve in the load sence line?
Plumb it like you would an outback valve.
https://outbackguidance.zendesk.com/hc/en-us/article_attachments/360018110913
I tried this, still the same. I’ll plumb it like a outback valve and that should fix it
