hi guys I have update the firmware of the f9p and use the arduisimple base confing files
do I have to change any settings on the message tab? I have done this 2 years ago but can’t remember
Would you mind explaining why did you update the F9P firmware?
If you picked up the exact corresponding base configuration from Ardusimple for the current firmware as you did for the earlier release, they should work as a base exactly the same way. However there is no single base configuration. If your configuration needed changes for the configuration file earlier on, it is impossible to say which changes you would need this time if you do not reveal the exact setup you are using.
