Base zed f9p configuration resets
Hi
I’m trying to setup a base with zed f9p and a raspberry pi and I configure the f9p with u-center but during rtkbase install the configuration of f9p is reset to default settings. After this satellites are visible in rtkbase but when I connect the f9p back to u-center it won’t be in survey-in mode anymore due to config reset.
If i configure the module again with the settings I want and open rtkbase it says “Main service is off or malfunctioning. Nothing could be displayed here.”. What’s the issue here and how to solve it?
There is no issue. RTK base will program the receiver like it needs to.
You need to set your coordinates in rtkbase.
