Berthoud Raptor with EC Tronic / DP Tronic
I’ve done a Berthoud last DP tronic last year. It had a GPS marked plug at the back which seemed to be an Y connection to the switches.
The pinout for the cable is here:
Today I tried the same on an EC tronic (except this has +1 section) and at section 11 I’ve found a 12v output when we switch the monitor to GPS mode.
In normal mode all these pins are pulled high when the switches are activated.
In GPS mode none of the LED-s of the switch activate. We did try to move but due to the noise it was hard to hear.
Should we expect the LED above the switches to turn on when AOG section control is on?
If anyone has such could he explain how it works?
Should we be able to send in more info over that port?
17 pins, 11 sections.
As for the connector:
Update: If you long press the “cogwheel” button it’s possible to set a couple features.
External sectioning over RS232 or CAN
Since AOG doesn’t really have RS232 sectioning yet I went the ISOBUS way.
I managed to get some promising signs from it but it’s not fully working yet. Collected the logs so hopefully someone smarter will be able to tackle it :slight_smile:
Yet another update :slight_smile:
Daan fixed the Task Controller so we’re passing the speed and the section states back and forth via ISOBUS.
Here’s the final result:
what you need for it (as of 2025 march :slight_smile: )
any adapter that’s supported by AgIso stack: Open-Agriculture · GitHub
I personally use the Aliexpress PCAN adapters. TYPE-C USB CANable USB naar CAN-bus Debugging Tools Converter Adapter Ondersteuning PCAN View Communicatiesoftware Python Cangaroo - AliExpress 1420
As for the software side: VirtualTerminal had to be set as V2 or older as V3 didn’t work. (but we don’t need VT)
Sections are controlled via a Task Controller: GitHub - GwnDaan/AOG-TaskController
There’s also a special AOG version.
I uploaded all these files here:
1 final piece where I’d appreciate some help. What’s the right connector here?
Pin 1 and 5 are for ISOBUS
looks like:
Hi,
Congratulations on this achievement!
Can this work with other ISOBUS systems, such as Teejet sprayer control? Or is this only written for the Raptor?
If it works with other systems, what precautions do you think should be taken before connecting? Can I lose the sprayer configuration stored in the ECU? (Perhaps it’s safer to carefully note this one.)
This makes AgOpen to appear as ISOBUS TC+SC and in theory it should not make any changes in the configuration.
I since successfully sectioned a kverneland Optima planter, collected logs from vaderstad tempo planter
