Hi everybody,
im new here and english was not my favorit lesson at school. Sry!
I have a problem and i hope someone help me, thx.
My Settings:
Trekstore Wintron 10.1
Win10 32Bit
Adrusimple with Ublox Antenna
AgOpenGPS 5.1.4
USB Connected
My Problem:
I have a delay between my driveway and that was my System shows me.
Its about more than a Minute.
The position looks correct.
How could that? what do I do wrong?
@littlefarmer Do you have the same Baud rate in Windows device management as in AOG for F9P and is F9P set up to 10 Hz and only NMEA on USB
UPDATE:
I have changed nothing and tested again. The delay is at 1 sec ±.
@pniels I try to check it. Thank you for your help.
@pniels I’ve found an difference between the Boud Rate at my COM Port in the Windows Device Manager and the Boud Rate at my GPS Port in AgOpenGPS.
I changed them to the highest Number on Ag used the same in the Device Manager.
I don’t understand what you mean about “only NMEA on USB”.
Please explain.
Thanks.
ah, okay. This looks like the configurationstool for the GPS Board.
Good, I search the the marked opition and change them if its wrong.
Thank you very much.
