fritz
8 August 2022 03:58
1
Hello im not sure im in the right place . My question is has any one used a MPU9250 instead of a BNO085 is it possible ? thanks chris
I use it in a witmotion unit.
As you know it is quite difficult at the moment to find IMU. So I tested this witmotion IMU.
[IMG-20220728-WA0009]
I have rather good results at least equivalent to the bno.
it uses the mpu9250 like the wt901.
the wt901 has the advantage/disadvantage of having the magnetometer activated (and I don’t think this is useful for aog so I see it as a disadvantage for choosing its location far from magnetic disturbance)
the wt61p or wt901 are available and arrive quite quickly.
I made a request …
fritz
22 August 2022 03:51
3
Hello Daniel Thanks for your reply im thinking that i will probably just wait for a BNO085 as im not confident enough or have the nohow . I was thinking of using Mpu-92/65 wich has the mpu 9250 in it i think thanks chris
