Boundary "lines" instead of curve?
I like using the boundary line feature for keeping my passes aligned along the edges of fields. The issue I run into is if I don’t disengage the autosteer before the corner, AgOpen will try to do a sudden 90 degree corner. Is there a way to set it up so it will go straight into the corner? I would rather not have to set up a line for each edge of the field and keep switching between them.
sorry, you need o set a line for each edge
you will soon get the hang of it,i did
and it will auto switch between them in use
How do I set it up to auto switch between lines?
What you can do is, after creating ab lines of all edges of the field, enable this function:
Its still not fully automatic, but it automatically uses the closest line depending of heading and position.
I had no idea it would do that, I will give it a try. Thanks for the replies
It doesn’t pick the line using heading, but this would make it much better.
It only looks for the closest reference line.
Or has it changed?
i find the line finder works better if you go on your line list and pause your AB line
I tried in simulator turning the tractor really changed the ab line depending od the direction its facing… it was the latest version
