Budget GPS receiver and tablet/computer
New to AgOpenGPS, so forgive me if this has been discussed before and I have not found the page yet. In search of a quality GPS receiver that has the capability to calibrate AgOpenGPS location by itself with the possibility of being retrofitted into RTK board down the road.
I watched a video (granted it was older software) where AgOpen GPS was run using only a USB GPS that was capable of sending NMEA comms. Ideally, this would be a good fit for our operation right now as we are only planning to use the software to manually steer and spray a couple hundred acres per year. Given that newer software is available, I have wondered if a bluetooth connection to the tablet/computer is allowable to run the software like the Garmin Glo 2. We have no issues with mounting the reciever to the roof of the cab either as I have looked into ardusimples basic receivers. But I remain unsure as to whether a receiver “must” have a board to connect to the software. Any help or recommendations as to a quality GPS for our intended purposes would be greatly appreciated.
Additionally, we will begin searching for a tablet to mount in the tractor to run this application, so recommendations regarding tablet/computer would be appreciated, too.
Welcome. The simple rtk2b board from ardusimple is the way most people go. https://www.ardusimple.com/product/simplertk2b-basic-starter-kit-ip65/
It will work fine on its own just plugged into a computer using USB and will blow the socks off the Garmin glo. And it can take rtk corrections and can be integrated into a steer board easily later on if you want.
Get a used Panasonic toughpad fzg1 and you will have a system for $500 dollars or so that will be easy to upgrade.
100% go the F9P. Can just plug in with USB to get signal into a laptop easily. And if you decide to upgrade to steering later down the line, you wont be buying parts twice
https://www.mouser.co.uk/new/ardusimple/ardusimple-simplertk3b-gnss-gps-dev-boards/
New variant, with built in tilt sensing. If anyone is designing a new board then maybe this is something to look at to see if it’s a step up.
Budget tablet:
