found some bugs in ethernet.
first arduino code:
// Send Data to AOG
#if (EtherNet)
int temp;
//actual steer angle
temp = (int)(100 * steerAngleActual);
toSend[2] = (byte)(temp >> 8);
toSend[3] = (byte)(temp);
//heading
#if BNO_Installed
temp = IMU.euler.head; //heading in degrees * 16 from BNO
#else
temp = 9999; //No IMU installed
#endif
toSend[4] = (byte)(temp >> 8);
toSend[5] = (byte)(temp);
//Vehicle roll --- * 16 in degrees
#if Inclinometer_Installed !=0
temp =(int)XeRoll; //roll in degrees * 16
#else
temp =9999; //no Dogs installed
#endif
toSend[6] = (byte)(temp >> 8);
toSend[7] = (byte)(temp);
//switch byte
toSend[8] = switchByte;
//pwm value
toSend[9] = pwmDisplay;
//off to AOG
ether.sendUdp(toSend, sizeof(toSend), portMy, ipDestination, portDestination);
then the parsing in agopen:
switch (port)
//autosteer
case 5577:
//update progress bar for autosteer
if (pbarSteer++ > 99) pbarSteer = 0;
if (ahrs.isHeadingFromAutoSteer)
ahrs.correctionHeadingX16 = (Int16)((data[4] << 8) + data[5]);
if (ahrs.isRollFromAutoSteer)
ahrs.rollX16 = (Int16)((data[6] << 8) + data[7]);
mc.steerSwitchValue = data[8];
mc.workSwitchValue = mc.steerSwitchValue & 1;
mc.steerSwitchValue = mc.steerSwitchValue & 2;
//build string for display
double actualSteerAngle = (Int16)((data[2] << 8) + data[3]);
double setSteerAngle = guidanceLineSteerAngle;
byte pwm = data[9];
actualSteerAngleDisp = actualSteerAngle;
//load the usb recv string with udp recd data for chart and gui info
mc.serialRecvAutoSteerStr = (actualSteerAngle * 0.01).ToString("N2") + "," + (setSteerAngle*0.01 ).ToString("N2") + "," + (ahrs.correctionHeadingX16 * 0.0625).ToString("N1")
+ "," + (ahrs.rollX16 * 0.0625).ToString("N1") + "," + mc.steerSwitchValue.ToString()
+ "," + (pwm).ToString();
break;
but not 100% shure how to display the steer chart..
