My old PCB v1 does not have A0 so I do not use any auto off system on my AOG v 5.5. Just a foot switch as steer button.
It is not posible to connect pressure switch via ads any more.
I have not tested pressure or current auto off, on my ver 5.5 systems, but your description indicates that the old ino bit for auto off , in ino is still used.
Do you use the latest version of ino?
Edit: I think latest for LEGO still is ver5 ino
Was your middle box (pressure turn sensor) green when you clicked Send+save ?
And did the box where I have 7 say: Pressure (bar)?
In the old V4 ino I know the reason for the needed two clicks to reactivate, was because turn pulses was set to 1,(meaning at least 1) so program needed the number two click to continue in the ino program. (ino pauses until you let it go on)
That ino part still looks the same to me!
