Can the offset fix be saved permanently to the field file?
I select the offset, check “On” “Keep offset even after field is closed.” I close the field. The offset is saved in the coordinates in the Field.kml file. However, after reopening and closing the field, the coordinates revert to the original ones.
Is it possible to make a permanent change?
