I have a Bateman rb26 sprayer, with a Harrison individual nozzle system controlling the nozzles. The system is working ok for now, but the interface is very dated and simple, with a lot of features missing that agopen has, like showing which nozzles are currently on and setting the rate. It runs on an android tablet connected via bluetooth to the canbus controller, then to control boxes on the booms that handle 6 nozzles each. The nozzles are opened by the sprayers standard air lines, with each nozzle having an electric valve operated by the Harrison system.
This is the cab box, here the gps inputs, the sections active from the joystick inputs, outputs the ground speed to sprayer rate controller and to bluetooth adapter to tablet.
Since aog will take over most of the operations, would I be correct in thinking the best place to sniff would be on the inputs into the module on the back of the sprayer? Another thought is to abandon the canbus system, and wire each nozzle directly to relays. Is having 48 relays a feasible option?
I have a board with 12 outputs that can do ~0.5A each so 4 of that on the boom would give you that 48.
It has a can transceiver so we could probably use just 4 wires.
but since you already have that I’d really try to figure out how that works
I stumbled across this menu that was buried in the sprayers control app, i didnt do any experiments as i dont want to mess it up at this point in the season, but it looks like it will show all the can addresses when prompted.
And it seems to me that we have Left / Right boom and each module has 8 outputs.
Maybe the center of the boom doesn’t have a “0” module ?
Each module covers 4m it seems.
Yes, that should help. 1 more spraying day left this season, then i can start experimenting. Thanks for your help so far, hopefully it will be a success.
