Case IH Puma 230, autosteer ready
At first, I was building your Schematic for the Pressure Sensor, but in the Version 5, you just can connect Signal from the Pressure Sensor to A0 on the Pcb. Then just activate the Pressure Sensor in the Menu.
Because I had the Problem, that when turning the Steering wheel, the count was only detected when steering in the opposite direction, stop turning the steering wheel or after a few seconds of turning.
But with the built-in Option with the V5 it works great, when set to 1 Bar.
