This is for old 7000 JD, work in progress, but all locking mechanisms i am making similar to this one. Robust and easy to make.
Thanks for adding the photos and the additional information. Great to be able to learn a little bit more.
Puma 165 (2017 model)
Does anybody has 3d models for CASE MX100c model? Could it be same as mxm150, which is shared before?
Case 9270 I think its a 1993
Did you upload the LH helical drive gear too?
You should be able to just mirror the print in the slicer to make the gear pattern match.
I would mirror the large gear so that your new large gear matches everyone else’s stuff. You could mirror potato’s pinion gear instead.
Oh ya that’s an easy way to do it
Have you got the screenshoot of all setting ( gain, pwm min, pwm max,… )
