This may have been asked already but I couldn’t find it but I would like to request a circle track option if at all possible.
Can you record a circular boundary, then use the make boundary curve function?
This should give you concentric rings in from the boundary.
I tried that last night a little bit and it pretty much worked perfect except for some reason there was a short section with it went a little crazy but maybe that was something wrong with the kml file I used for the boundary. I will keep playing with it. Thanks for the response.
