I’m writing this posts, because I had a lot of trouble getting Agopengps on my Case Puma 200 (2012) to work. Overall it seems like a very tricky Valve to find good settings for, therefore I’m posting mine as references for somebody whos in the setup phase.
The only issue with my system is, that its still running on V4.3.1 because I just couldn’t find good Settings for these Valves in the V.5.
My System includes:
-Dualheading (Hammer Code)
-PcbV2 (Hooked up to the OEM Harness behind the passenger seat)
-Panasonic FZ-G1
-OEM WAS
-OEM Pressure sensor (I modified the V4 Code to shut of my Steering after the Sensor receives a high enough pressure level.)
-Steer Switch per Button
-Work Switch per Switch
-OEM Hydraulic Valves
Now my Settings for V4:
Gain: 12
Min. PWM: 32
High Max PWM: 100
Low Max PWM: 55
Pure P:
Look Ahead In Seconds: 2,8
Look Ahead Offline Multiplier: 1,8
Min Look Ahead in Meters: 2
UTurn Look Ahead Multiplier: 0,8
Feel free to post your settings, if somebody has good V5 Settings i might give it another shot.
UPDATE: Got it working with the newest Version (5.6.0)
My Settings are:
P: 30
MAX: 100
LOW: 70
MIN: 43
PP:
Look Ahead: 2,8
Look Ahead Speed Gain: 2,4
Sidehill Deg…: 0,10
Integral: 11
I’m not quite sure about the Integral, but these are settings that work pretty good from Low to mid speeds, high speeds like 20kmh, but i will try more this season.
Edit: A few pictures of my setup:
The OEM harness gets plugged in, the grey cable is for my steer and work switch. With one USB cable theres also a reset and on off switch. To be honest these two switches are useless because I’m powering everything with ignition power.
