Confused about wiring
I am confused as to how I need to wire up a single valve to a Cytron board.
I have a proportional directional control valve so i have two electrical connectors. I presume each two-pin connector has GND and PWM. So I need two PWM signals to operate it.
I have the Cytron MDD10A that has two PWM channels and two direction pins going in and two motor coil connections coming out.
How do I wire the output of the MDD10A to the valve?
Looking at this diagram it seems MA + GND goes to one solenoid and MB + GND goes to the other solenoid?
Thanks, Andy
Yes you have the correct wiring.
Thank you! Andy
