Confusion about Certain Components
Hi! I’m using the AOG v4.5 Micro PCB and the Keya Canbus Steering Wheel is the steering option I’m using. I’m ordering components for the Ampseal and I’m just a bit confused about what the “connector for the motor” is on this part of the documentation: AIO Ampseal Wiring Harness | AgOpenGPS Documentation
Could someone clarify if that is only for those steering with a motor rather than the Keya steering wheel? Do I need to get a different connector instead, or is it not needed since the Keya steering wheel is supposed to be powered separately rather than through the PCB? Thank you!
I believe the keya comes with its own cable.
There will be a cable that needs connecting directly to a decent power supply then there will be i think 2 canbus wires that you connect to your pcb. The keya isnt powered by the pcb
Thank you!
