I was going to connect my Ardusimple into Tony’s CAN board - What do I set the IORef on the Ardusimple 3.3V or 5V?
Also, is it Tx1 on the Ardusimple to Rx3 (Tony’s board) or to Tx3 ?
Plug Ardusimple straight to your pc USB port. AOG will read it from there through AgIO.
IOREF to 3.3v
TX1 F9P - RX3 PCB
RX1 F9P - TX3 PCB
There is two programs for it:
I do need to update them and also merge into one with the option to select via the service/options menu
Brilliant working well.
I’m assuming the PANDA branch will be the better of two to use, any downsides to that ?
