Connecting 2 casters to AOG
Hi, is it possible to connect 2 casters to agopengps? I am using rtk2go as my caster currently, and have noticed that once in a while it will stop working and I have to wait a second for the base to come back online. Is there a way to set up a back up caster that aog will use in the event rtk2go stops working? I have my rtkbase setup to send corrections to rtk2go aswell as centipede, I’m just not sure how to set up aog to do this.
Thanks!
You can set a separate agio profile. There’s no way to use two casters at once.
I use rtk2go as well, but my connection issues come from my android phone. When phone shift provider mast,(terrain and woods sometimes block the nearest mast which is only 1 km away, the other is 2 km away, when driving in that problem field). It seem that IP address shift, which ruin the connection to rtk2go. I have to disconnect and reconnect in lefebure (sometimes I turn off and on mobile data in the hope to get new IP faster)
Normally I get connection before rtk time runs out :slightly_smiling_face:
