Before agopengps we only used claas s10 terminal which had such featute as contour. Mainly used this feature in headlands and sometimes for other work. I can’t seem to find similar option in agopengps, and is it possible to add?
I was thinking about contour that is based of previous work width, not fixed contour. Maybe i explained it bit wrong.
The “contour” button should do what you want.
P.S. The screenshot I took was my own WIP project, is why it looks slightly different.
Will look into it.
Is it contour as above or simply ABCurve that you are after? A separately recorded contour path or one created from the recorded field border? Everything available from AOG.
i think you can see this example of aog reality
in this parts of video :
https://www.youtube.com/clip/UgkxNT6qqzD42jMTc9gmP6R7bGqi4miXBDXj
Which you will look into it?
Misunderstanding solved. Everything is just were it needs to be. Problem was in the washer between the seat and steeeing wheel.
