I have been playing with the AOG user interface. This could all be setup but I basically just left the tractor implement set as default while I am playing with the user interface.
Is there a way to set the control point to be the center point of the implement instead of the center of the rear axle on the tractor?
I have had this question too… does aog try to get the implement to the center of the line, that’s where it’s all about after all. But I could never see any influence of different tool settings to the steering of the tractor.
AOG experts should comment this but I don’t think AOG aims at the implement on the wayline but the tractor instead. Implement geometry is there for coverage painting. My understanding is that only AGCO (Fendt) has the option to aim the implement to the wayline. Then Trimble and some others have active implement steering options but they need another antenna on the implement.
My thought at first glance on this is it should be fairly simple to do. Right now the steering algorithm takes the front axle to be the front axle. The wheel angle is the angle of the wheel to the front axle. Then it keeps the center of the rear axle on the guidance line.
What if instead we looked at the tractor as a whole as being the front steering tire and the towed implement axle location is the rear axle and control point. Then the wheel angle would actually be the angle between the tongue of the implement and the drawbar of the tractor. This seems like it would work. What are others thoughts on this. The location of the gps antenna relative to the hitchpin in the drawbar would be critical to correct for the location change of the antenna when the tractor is turning.
What are the thoughts of the experts out there.
Driving around in the simulator I definitely get skips and overlaps when running contours. Unfortunately 90% of our farm is contours not AB lines.
Some of the geometry on sharp curves ends up being impossible regardless like turning a 90 degree corner catch my Steiger video on youtube for an example. Even the human cannot accomplish the task.
You can only control what you can measure, so in simplest terms what you describe would need a second gps unit on the implement as well. To notify the tractor that more correction is needed.
AOG is already being tested with implement steering in addition to the tractors if your equipment is equipped to do so.
But I would just try AOG out first. Its pretty solid at covering ground with minimal overlap. All Brands of GPS have there accuracy reliability rated at 95% of the time. Nothing is perfect.
The goal is the center of the implement. The linecis drawn ceter of the tractor. It is offset to put the implement on the real line.
Make an abline using the form. Make it somewhere away from you. Make it with no offset. After it is made, get on one of the lines and start autosteer. Once steering well and following the line stop the tractor. Now go set an offset of half your tool width. When you toggle autosteer the line will jump over putting your implement in line with where it was, and your tractor far enough over to drag the implement there. Now do a uturn and you can see it.
Hope this makes sense. The tool guidance is a separate feature being tested. It guides both tractor and implement. The implement has to have some sort of steering. There are basically two lines. A fixed system can’t follow two lines. One has to win. An adjustable ( tool steering) can follow two lines, until you are out of capacity.
I got PANDA to work last night, it felt like winning. Have not had a ride on any branded system that drives like that. Its much better on the small mower, so will be overkill for grain farming.
I did my potato planting and ridging with panda this year. It drives very nice but with heavy hitch mounted implements that couse draft there is still a few cm error sometimes. (has nothing to do with panda, that eliminates the steering wheel to go crazy on bumps and that works really nice!)
I am running it between 5 and 10 mph. typical planting and working speeds.
I mean I have had it running at 45mph but I don’t expect it to perform well at that speed. However it seems to make little difference.
I have parts ordered to get a real life system going. I will do some testing with it. I am sure it will be more than adequate just questions as I am starting with the system.
That’s my biggest issue with the small tractor, AOG is trying to correct but the front end gets light. Or on side hill the implement wants to start steering.
But it is way more stable on Panda, now if it wiggles its due to low DOP only.
