I have been planning to setup my own base station since we have no cell coverage, and not enough Wi-Fi coverage in the target work space, but our state has a CORS system and I got to wondering:
Is there a way to adapt an internet connection to the CORS system to work on a local 900 MHz wireless system? If so, what is that method called (I can’t figure out good search terms)?
More specifically, I was originally planning to use a Base and a Rover unit with the X-Bee 900 MHz link from Ardusimple. Is there a tool or application I can use to replace the Base unit, and act as a gateway between the CORS network to the X-Bee 900 MHz connection?
Thank you, Chris
