I am working to get my first AOG system up and operational. Everything is checking out and working as it should, except my Cytron appears to not be outputting any voltage/signal? I made the free wheel modification as mentioned in other threads, so I’m not sure if the manual MA/MB switches to operate correctly? When I push them, nothing happens(the MA/MB lights don’t light). I have been trying to use the wizard to setup the system initially, and I get the auto steer icon to switch from red to yellow, and the green AS light comes on, but no power from the Cytron? Is it possible that the Cytron is simply bad?
The three pins will work without the cytron modification but with the mod you need to connect the nc pin to pwm2 on the board. You can use it the way you have it and just add the plug with the red wire to connect to pwm2
Hi guys new here, have my system almost up and running but looking about the freewheel mod.
My board is the same as that posted by cowhound above and only has the three pins(dir, pwm1 & gnd) soldered to the board. I don’t have the plug for the cytron and I’m just wondering if I can solder directly from the pwm2 hole on the pcb to the trace point on the cytron that normally is soldered to the NC pin of the plug?
