Heading
GPS Heading From
I can only take a choice once a time between Fix, VTG or Dual.
I think, what Franz means is, using the new (cool) data sources dialog box, you can’t select HDT, it is allways jumping back to VTG.
Yes I changed the names, but not the correct saving of the names. Was thinking Fix, One, Dual would make more sense. Can’t translate them since the actual Text is used in logic, but the description can be translated.
Thanks for finding this.
Edit note: this is for version 4 only
