daner
January 6, 2023, 7:56pm
#105
I think i have even more then 100rpm,
Fuse rated for this motor is 50A at 14.5V so it’s very powerfoul.
But there is no need for that power becouse there is no force on steereng wheel.
My concern is change direction amps, but it is a spiral transmision , maybee its diferent then gear.
daner
January 8, 2023, 11:03am
#106
Measured it today , 130 rpm/min
my apologies for my bad english. Does it work well with this steering motor? I’m looking for a good alternative to the phidgets that are a bit smaller in size.
Daniel
January 12, 2023, 7:17am
#108
I have several that have been running smoothly for over a year! you will be surprised at how strong it is even at 12v.
for example a friend purcharse a small MFA 970D
https://www.gotronic.fr/art-motoreducteur-mfa-970d471-12413.htm
and he was really happy to begin with this
daner
January 21, 2023, 2:08pm
#110
Connected it works
https://youtube.com/shorts/UwIcfJKv758?feature=share
Now need to work on estetics
I quickly put this together to test the motor.
Now cablework
These are the installs I love the best! The ones with a tractor with hard earned patina…. and newly minted U turn!
You steering motor handles very precise, great implementation.
daner
January 21, 2023, 8:41pm
#112
But it is a smal tractor ,when becames litle grumpy steer goes to hell 10 cm left right.
I hoped the panda will solve this , but it doesnt.
Or maybe i did not set something right.
I must try with antenna in front, its half of height, maybee it will do better.
Antena in front, drastic performance increase
https://youtube.com/shorts/7dx3CTsS18c?feature=share
ryan
January 21, 2023, 10:35pm
#113
I have watched this video several times but couldn’t figure out how he built, am i the only one wondering?
ryan:
6 small brushless motors, instead of one big expensive
They seem to have their flywheel covered in rubber - or the red inside the wheel is rubbery
Another design, Arag Polaris.
D20339_GB-m00.pdf (792.2 KB)
Which is the one FieldBee use I believe.
daner
January 22, 2023, 7:28pm
#118
If i didn’t make my motor from car, my next idea whould be something like this
US $200.55 28%OFF | Hollow Rotating Platform Gearbox 2Arcmin Round Dsk Reducer, Nema17 Stepper Motor Ratio 5:1 10:1 Hollow Gearbox,Shaft 5mm/8mm
