Is that worm-gear type? No experience but would it have a lot of play especially when worn out a bit?
Yes it’s’a worm-gear type but it has a particularity with The back-driven possibility. The objectif is to let The motor engaged Even not using autosteer.
Coming week we offer totally free shipping with code AGopen. We are EZtronics.nl, one of the oldest webshops in Europe and selling the Phidgets 3269_3 motor, also the 3269E motor (Encoder pre installed for you) or a Kit that includes 3269E, Phidgets motorcontroller and all cables.
Find all CEREA/Autosteer parts here (note our webshop is updated, old links may not work): CEREA
The link is now updated to: 24V/5.1Kg-cm/588RPM 4.25:1 DC Gear Motor
greeting
i read that you are using the IBT2 driver.
can help with connection, how to connect it.
i have this pcb board.
I don’t expect the IBT to be on the board but somewhere next to it connected by a piece of wiring to the main PCB.
I think all the signals you need are at this connector. They are labeled for the Cytron but when you select IBT2 in AOG they will output for it. Off the top of my head I’m not sure how they connected to the IBT2
Thank you
I guess someone else will give a suggestion on how to connect
Can anyone recommend a seller for the 24v Phidgets motor, that ships to Sweden?
Some time ago I ordered an engine on this page. and they sent it to Spain, I don’t know if it will help you 24V/5.1Kg-cm/588RPM 4.25:1 DC Gear Motor
Is that the Phidgets motor or another brand?
Phidgets
http://www.eztronics.nl/
Delivered all my phidgets fast and decent.
