Dell 5290 dock/mount
You guys using the Dell 5290, how are you mounting it? I don’t find any supported dock with ethernet so you’re using USB C to Ethernet adapters and charging through the other USB C port?
Yes that is the way I use my Dell 5285.
What do you use for mounting the tablet?
Well !! Had an old pivoting mini wall displaymount and added a couple of alu profiles and 2 mirror mounting clips with a spring at top.
