Just for information, did you order the option
“Ublox F9P Konfiguration für AgOpenGps und Firmware aufspielen” when you ordered your pcb?
I did yes.
Ok, then your F9P should be already configured correctly.
Yes that end should be fine, I haven’t set up the base station yet so I have nothing to connect to. I can see the signal from the antenna but the software is still lost, just like me😅can it be set to connect to a non corrected signal?
You should able to get gps signal in aog without ntrip configured / enabled, if your antenna has a free sky view. May be you can use a free ntrip service via www.rtk2go.com for testing.
Success! I changed to the baud rate to 115200 and everything came to life.
