I have made a field and created a boundary, then I record a path. Next trick is to go back and have AOG actually drive it. When I push the go button (martian guy flyout menu) I get a message that no path is found. The path was created by recording from my favorite Martian
I was just about at the starting point of the path. I might have even been on the line but past the start point. Is there a “rule” on how a path should start and stop? This is a test just to try to learn how it works. In real life this would be a path to spray around trees.
A Martian works only within the boundaries, the entrance to the path must be made so that the tractor mounting on it does not go over the border!
As there is a problem with that, you can make the border moved further than the real one.
