Is there an editable (EasyEDA, etc.) copy of the AIO v4.1 PCB schematic available? I can find the PDF version but that is not editable.
It is in the boards repo. Should be a file named EASYEDA
I found them. Just didn’t dig deep enough. Thanks!
Where is that? got the same issue unable to find the easyeda file… only the gerber, pdf & co.
v4.1 Misro I have not seen. I was after v4.1 STD to do some work an the UM982/Bynav TX/RX reversed issue.
v4.1 STD:
v2.5
I’m looking for the micro, so no luck for me.
Micro is highlighted in blue.
unfortunately it is the v3 not the v4.1 and I’m not sure the part I want to check is the same or not…
I’m going to try now
Thank you it is the correct one now
