I’ve had a lot of problems getting autosteer working over the past year or so, it’s always been intermittent. Works in the lab, then doesn’t work in the field, I may have worked out why.
Can anyone explain the relationship between the on board (PCBv2) autosteer switch (PD6), the Enable Steer function in AOG and the autosteer button in the main GUI?
I’m not using a switch or button on the PCB, so PD6 is permanently grounded. As such, I didn’t think the Enable Switch function needed to be on, just thought the user had to enable it (and u-turn) in the GUI.
What is the relationship between these three?
Thanks ![]()
*The Steer Indicator is a brilliant diagnostic feature!
