hello, could someone tell me, how to connect the pressure sensor on the autosteer valve of a New Holland T7 to exit autosteer mode. There are three pins on the connector … Thank you. jlpic
You can see in the forum of projects / success stories / case puma ih 230 the comment number 10 of Hansdampf, which says that it connects the signal in A0
And if you are still using 4.3.10, like i do for now, if coded the Feature from V5 in V4.3.10. But i just did it with Voltage and didn’t map it to Pressure or Amps.
If somebody needs it text me ![]()
