I have almost finished setting up agopengps but I have a small problem:
I’m trying to set up a system with err = 0, but the engine only runs in one direction.
When I press MA or MB the motor turns right and left
I have the latest version of Release 5.4.5
I have a BNO055
Please post a picture/print screen, showing the error.
Are you working in this screen, and can not steer right or left with the arrows beside the green tractor?
you can see the video, the engine always tries to go in one direction and does not correct to go in the middle (my wheels are straight)
Maybe change was direction (in aog setup, see the manual)
This video is also good: AgOpenGPS v4.6 Beta Test - YouTube
Edit Invert Was or invert motor dir:
When I inverse was or dir it’s the same… I don’t know where the problem comes from
WAS should be positive to the right.
SjaakA
2 February 2022 16:10
7
I would check the wiring between the Cytron and PCB. Yellow should be DIR. (direction)
wland
2 February 2022 16:14
8
Check if WAS Signal is correct
Basic Steer Settings - YouTube
I followed the instructions and it’s still the same… I also redid the wires between the cytron and the card
MB and MA work
I’m going to install the nano again
wland
2 February 2022 18:57
10
Which pcb you are using? I just noticed that Kaupoi pcb has a solder bridge IBT2 MD13s beyond the nano. You can try changing the nano, too.
I use kaupoimod v3.0.3
With agdiag it will be possible to see where the problem comes from quickly, right?
wland
3 February 2022 10:38
12
You can measure the voltage of DIR-Signal to doublecheck if your nano is working correctly
matias
3 February 2022 18:17
13
Hi! upload to arduino example EEPROM Clear and then upload the correct ino file. I suspect you have previously uploaded other versions of the ino file
I changed the arduino, and it works!
matias
3 February 2022 19:23
15
the previous one is 99% functional, but its memory is cluttered
