trying to setup a new board but i can’t get BNO085 from Mouser to show roll correction or get the “green box” in agopengps. i tried another known working BNO085 from another unit which works fine so that tells me the board and teensy are good.
(i actually bought 2 BNO0085 from Mouser and they both don’t work). what am i missing? they don’t have to be programmed do they? appreciate any help thanks.
If you connect right when the teensy starts up, you can check if the teensy is recognizing the IMU. As you can see here, this shows the teensy is reading from the bno08x.
It could be that you just got a bad bno… I’ve heard some estimate every third bno is faulty. What we get for using a $10 IMU I guess…
on my serial monitor on startup i only get the panda messages… nothing like you had that shows things starting up?? not sure what I’m doing wrong as i deleted log before powering up teensy… thought i would see the same as you
that would be pretty bad luck that two brand new BNO would be lemons… but it could be possible i guess
i got 1 of 2 working after i re-did the gnd solder joint as it looked like it was lacking a tiny bit on one side of the pin ( it didn’t look that bad although). all the other joints look good on the bno that isn’t working, but maybe i need to redo all of them this week and give that a try. thanks
good to know thanks! trying the RVC mode i would need to modify the V4.5 board in only two spots correct (first where it says to solder and second where it says to cut trace)?
