Excentric mecanism for gear steering
hello
I just tested a new concept to connect gear to gear with an excentric solution
Today the excentric permit to have 12 mm of range that can be convinant with majority of gear size
as advantage -When you rotate the excentric automatically the gear rotate taht can be helpfull for syncronyse gear teeth
-There is no adjustment
  • there is few parts
as drawbacks
-It is really slow to activate and desactivate it
  • Lot of friction due to big diameter and small play
I do the metal sheet version as only cutting version and a version to 3D printer
You can see the result :
and download the files :
