Hello, I am new here but excited to learn about agopengps! I work at a farm research association and we are in the process of purchasing a new small plot seeder. However, ideally the plot seeder needs rtk with autosteer, and the quote for that from John Deere is over $40000! I talked to the seeder manufacturer about using other options and he said the main thing is the seeder needs a 12 volt signal at the determined spacing for the plots so it knows when to engage the seeder for each plot. He mentioned that tree planter mode might be an option on some systems. I was excited to see that there has been a tree planter mode, at least in the past, but I can’t seem to find it in the new version. Any ideas on whether we can make this work for us?
Plot?
You need a signal per seed/plant or a zone?
If there are zones, just the section control could do the trick.
Ok, that’s an interesting idea, I hadn’t thought of using section control. I’ll have to look at the details of how section control works. Any quick links to get me started?
Thank you so much!
