F9P as basestation works after survey-in but not in fixed mode
Hi,
Setting up an Aurdusimple F9P as a base station to send updates via xbee radios (straight 900Mhz radios, so no NTRIP or anything). It works if I set the Time Mode to Survey-In (after the survey completes of course). And by works I mean the rover receives the RTK corrections and uses them.
However when I set the base station to Fixed Mode, and set it to use LLH, and provide the Lat, Long and Elevation in the configuration, the rover will not use the RTK corrections. The rover does not receive any 1005 messages but it does receive the other messages 1074, 1084, 1094, and 1230. I have gone all through the config settings multiple times trying different options, but I can’t find what I am missing, or what the issue is. Without the 1005 messages, the RTK corrections are not used by the rover. The 1005 messages are received by the rover if using the Survey-In mode.
The other difference is on the base station in u-center. When set to Survey-In that status is TIME (after the survey completes), but the status when in Fixed mode is No Fix.
I prefer to put the exact coordinates in and use the base station in Fixed mode for consistency.
Anyone out there experience the same thing or know what is wrong? I have put a bunch of time into so far, but haven’t been able to figure it out, so any help is greatly appreciated.
Thank you,
Kyle
I had that same problem but ucenter is such a black hole to me I don’t remember exactly what the solution was.
I do have this picture which might help you.
Cowhound, you are using the ECEF x,y,z coordinates, not the Lat/Long/Alt coordinates which I was using. I did not know what the ECEF referred to when I was trying, so I went with Lat/Lon/Alt. I have since googled ECEF and will try using that coordinate system to see if it works better in ucenter. Thanks for the idea! I’ll post my results once I have had a moment to try it.
It seems solved. For anyone else having this problem, there appears to be a sanity check built-in and if the coordinates you enter in the fixed position are too far from the GPS coordinates the unit will not go into TIME mode, or at least that seems to have been the problem.
Since I was just testing, I had used coordinates I knew from a field close by for the fixed position, but seems that wasn’t close enough and it would not enter TIME mode. Once I got more accurate coordinates for where I was testing the system entered “TIME” as expected.
